[GB]MKC75 PCB Gasket Mount Customize Keyboard -Full Pricing, Vendor list, Review Links and Pre-order Information Updates
Mykeyclub2023
31 Jul 2023, 08:08
Hello everyone,
First and foremost, as MKC's inaugural independent project, we'd like to express our gratitude for the tremendous support. We aim to give all our customers an even more excellent thank you. We are thrilled to announce that due to the sales meeting our expectations, our team has decided to include an additional bonus for this presale - the MKC Stabilizer Set. With just one week remaining until the PRE-ORDER end, don't miss out on this fantastic pre-order purchase and Bonus.
MKC75 Pre-order Information
MKC75 Renders
MKC75 Pricing
MKC75 Pre-order Page
Pre-order Bonus for all MKC75 Keyboard: Carry Case & MKC Stabilizer Set
Pre-order Time:
From August 5th to August 31st.
Estimated Delivery:
Start packing and sending to vendors and Mykeyclub direct customers around November based on the final order QTY.
Vendor List
- US: KeebsForAll
- US: Cannonkeys
- Canada: Ashkeebs
- UK: Prototypist
- Germany: Candykeys
- Spain: ELOQUENTCLICKS
- Italy: Coffeekeys
- AU: SwitchKeys
- South Korea: Geonworks
- Singapore: Mecha.Store
- Japan: Basekeys
- Vietnam: MOKB STORE
- Philippines: Zion Studios
- Malaysia:Rebult Keyboards
- Indonesia: KeebsMark
- Thailand: NTCH Keys
- Bangladesh: KeyB
- Argentina: LATAMKEYS
- Colombia: Stiutech
- Taiwan: 鍵盤好貴
- International: Mykeyclub
MKC75 Information
Features
- Supports Caps Lock Indicator Light
- 100% processed using CNC machining with 6063 aluminum case
- Compact 75% layout
- Three-in-one structural design( Top Mount, Plate Gasket Mount and PCB Gasket Mount )
- Supports tri-mode PCB(Wired, Bluetooth and 2.4ghz)
- Supports Plate, Half Plate and Plateless Build
- Supports rotary Knobs components and Light Signs, which are also compatible with JRIS75 Rotary Knob/Badge/LED Light Sign
- Supports Alu Internal Weight
- Multiple configurations available
- 2 x 2200mha large battery capacity
MKC75 Specifications
- Dimensions
- Typing angle: 7°
- Front height: 18.5 mm
- Material: Full CNC 6063 aluminum
- Dimension: 320*134.4*33mm
- Three-in-one Structure: TOP Mount / Plate Gasket Mount / PCB Gasket Mount
- QMK/VIA Supported(wired)
- Support PCB stabilizers
- Unbuilt Weight
- With PVD WEIGHT: 1.693kg
- With Alu WEIGHT: 1.425kg
- Built Weight
- With PVD WEIGHT: 1.86kg
- With Alu WEIGHT: 1.592kg
We have adopted a three-in-one structural design for the internal structure, which can support regular positioning plate gaskets, PCB gaskets, and the long-disappeared TOP Mount structure. Thanks to the consistent frame of the compact 75% layout, we can make the three structures perfectly compatible.
- TOP Mount
- Plate Gasket Mount
- PCB Gasket Mount
Case Colors Options:
We adopt 17 case color cases and want your ideas for other new colors.
- 4 E-coat case:E-white, Milky White, Pink, Lilac
- 6 Anodized Case: Orange, Black, Brown, Grey, Silver, Green
- 7 Color Combose Case: E-White&Black, Orange&Black, Grey&Black, Silver&Black, Wine Red&Black, Deep Blue&Black, Green&Black
Weight Options:
Designs:
- Blank Weight (Default)
- Cursive Text Weight (Add-on only)
Colors:
- 4 Alu Weight: Gold, Silver, Black, Rose Gold
- 6 PVD SS Weight: Gold, Silver, Black, Blue, Rose Gold, Chroma
PCB Options:
- Wired Flex Cut Hotswap PCB( 1.2mm, Multi Layout , No Per-key RGB, 7u split spacebar,support QMK and VIA )
- Wired Non-Flex Cut Hotswap PCB(1.6mm, Multi Layout, No Per-key RGB, 7u split spacebar, support QMK and VIA )
- Wired Solder PCB(1.6mm, Non-Flex Cut, Multi Layout, No Per-key RGB,7u split spacebar,support QMK and VIA )
- Tri-mode ANSI + ISO Hotswap PCB (1.2mm, Non-Flex Cut, No Per-key RGB, support Mykeyclub Software)
- Wired Per-Key RGB Hotswap PCB (Add-on only, 1.6mm, Non-Flex Cut, ANSI Layout, support QMK and VIA )
Noted: The Tri-mode technical support is provided by IRISLab. Really appreciate their support and help.
Plate Options:
- Flex Cut Plates: FR4, ALU, Brass (Brass Plate Add-on only)
- Non-flex Cut Plates: PC, POM
- Alu and FR4 Half-plate (Both Add-ons only)
- Plateless
Noted: We highly recommend using a PC/ POM/FR4 plate for Tri-mode PCB because the Brass and ALU plate will have a little affection for connectivity.
What's Included in MKC75?
- Full CNC Aluminum Top case *1
- Full CNC Aluminum Bottom case *1
- Weight(Anodized Alu Weight or Stainless steel PVD Weight) *1
- Internal Alu Weight (Only for the Tri-mode Version Case) *1
- PCB *1
- Plateless or Plate *1
- IXPE Foam *1
- Poron Case Foam *1
- Poron Plate Foam *1
- Type-C Daughterboard with JST Cable *1
- PCB GAS Silicone Column *12
- Plate GAS Silicone Sock *18
- Top mount screw and spacer *12
- PCB stabilizers o-ring *12
- Footpad *6
- Poron case strip *6
- 1.6mm hex key *1
Gift(will not send make-up or replacements)
- 1 Pack of Extra Screw
M2x3mm cylindrical head screw *2
M2x8mm cylindrical head screw *2
M3x12mm countersunk screw *2
M3x6mm countersunk screw *2
- 2200mha battery (Only for the Tri-mode Version Case) *2
- Silicone pad of battery compartment (Only for the Tri-mode Version Case) *2
Review links (Stay Tuned for More)
Content-------------Creator Prototype
Switch and Click-------------Green Case+Chroma PVD Weight
Hipyo Tech-------------Lilac Case+Chroma PVD Weight
Simulator Tech-------------Green Case+Gold PVD Weight
whnkeys - Soundtests-------------Green Case+Gold Alu Weight
Rx003-------------Pink Case+Rose Gold Alu Weight
KSJ KeeB-------------E-White&Black Case+Chroma PVD Weight
MechTech Keyboards-------------Deep Blue&Black Case+Blue PVD Weight
Captain Sterling (Prototype)-------------Orange Case+Black PVD Weight
Mykeyclub Team
We are a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys. Please participate in our MKC family for more discussions and future updates.
MKC75 IC Form
Mykeyclub discord
Mykeyclub Ins
Best Regards
Mykeyclub Team
