Desoldered the switches and glued 38 switches together:
And soldered the diodes (10 columns and 4 rows):
Then connected to an Arduino pro micro and flashed the firmware (I used qmk firmware):
Cut the kecaps (still need some work with the polishing):
I put some polyester resin on the top to make it more comfortable to type on (later I would use colors for the resin).
Here is the picture comparing to my Noppoo mini choc and my DIY bluetooth 33-keys board:
and of course with the phone:
I am quite happy with the result and thinking of making a case for it (maybe use the Bluefruit EZ for Bluetooth if I still could manage to put everything together in an acceptably small form).
PS: Many thanks to matt3o for the instruction
