Latest update post: https://geekhack.org/index.php?topic=88 ... msg2477138
Introduction
Katana60 is a symmetrical row staggered PCB that is compatible with standard 60% keyboards and standard keysets. You can use Matias/ALPS switches in any of the compatible layouts, and there is a layout which is compatible with an AEKii keycap set. The idea of the compatibility layouts is to reduce costs when it comes to hunting down keys for your new board.
Compatibility
This image illustrates the multiple bottom compatibility options available on the PCB. The MX and AEKii labels are a guide - you can use whichever layout you want with any switch type, though in order to use the AEKii compatible stabilisers, you will need to get your own plate cut.
KLE compatibility:
http://www.keyboard-layout-editor.com/# ... 989bd6f36c
Or image:
Great for touch typing
The board is symmetrical row staggered, which is great if you're a touch typer and/or you use Dvorak/Colemak layouts, or any other layouts optimised for maximum home-row time. The idea here is that you rarely need to move your hands from the home row, making it more efficient and ergonomical.
Many ergonomic keyboards on the market tend to be expensive, require completely custom keycaps sets (adding to the cost) and have an odd shaped case. Trying one without being sure if you'll like it requires a leap of financial faith. The Katana60 will be cheaper to try, and you can choose one of many 60% cases, giving you a lot of customisation choice.
Plate PCB and Pricing
There will be a universal plate available at the same time as the PCB. The PCB supports PCB mounted Cherry stabilisers, though you can make your own plate with plate mounted cut-outs if you wish. Though the original intention was to launch a group buy, but the Katana60 will instead be made available at http://candykeys.com
The PCB and universal is currently being quote up and prices will be revealed soon. I welcome all of your feedback, please leave your comments below.
Original post:
