Anyways, here it is (click for full resolution):
My unit looks to be in worse condition than the one that's owned by the Computer History Museum, but it's not the worst looking beamspring board I've seen.
The side profile somewhat resembles the Displaywriter keyboard.
These vents appear to be for air circulation for the controller board.
The IBM badge has rusted, and the adhesive has completely degraded.
Some more vents on the bottom.
This board may have spent some time outdoors.
The controller is detachable. I didn't find a solenoid.
Date codes indicate the controller was manufactured around 1979. Note the use of two 30 pin edge connectors instead of the single one that's typically found on other beamspring boards.
The support structure is made from discrete parts instead of being cast or formed from the bottom housing like some other beamspring models.
The back of the top housing has retained its nice off-white color. It is made of plastic.
In the future, I will do a full teardown and cleaning of the board. A conversion to USB would probably entail laying out a modified controller, but it looks to be doable.
Hope you guys enjoyed this first look!
