Hi,
So recently I won an ebay action for this very dirty model F AT for a very nice price and I was wondering if anyone know of a seller for keycaps. At the moment im just substituting keycaps from my xt model f and it works fine, but im hoping to get it looking a little better than it does now.
Sent from my SM-G935W8 using Tapatalk
Keys for the IBM Model F AT
- Main keyboard: Model F122
- Main mouse: M510
Keycaps are interchangeable between the Model M and F. But if you buy them from Unicomp piecemeal, you will get mismatched fonts. You're better off buying an entire Model M from them and using the keycaps (at $84 they are a steal). Or buy a broken Model M on eBay as Wolf123rt suggested.
- DT Pro Member: 0167
The APL sets are a little better but honestly you get a total shit show from unicomp if you buy just a normal set.
I would do with a busted model M , or a terminal model M they go for less.
- digital_matthew
- Main mouse: It's a Secret.
Yeah terminal Model M battlecruisers can be found for less than a new Unicomp keycap set.andrewjoy wrote: ↑The APL sets are a little better but honestly you get a total shit show from unicomp if you buy just a normal set.
