Got some AT101W Caps without stab wires. The matias replacement ones cover the 2u keys nicely, but the spacebar wire is too short. If someone has an extra, I'll gladly take it off your hands.
Thanks.
AT101W Spacebar stab wire
- DT Pro Member: 0167
I am in a similar boat , i need a longer wire to make the ALPS caps i got fit properly on my filco zero.
When i get some wire in that's the right size i will see if i can make you one.
- abrahamstechnology
- DT Pro Member: 0212
What about flipping the stabilizer inserts around?
I actually have an extra wire right now.
