I thought that I would do a little tour of my daily use keyboard to show to you.
What I have is an Apple M2454 which came bundled with a G4 PowerMac from 1999
I removed the keys to do a little cleaning
The switches appear to be (not switches at all) but little rubber domes with a small radius which makes them feel better than conventional (wider radius) rubber domes.
If I remember correctly the actuation force was 64g
Thanks guys!!
~Reddog9287
