![Image](https://i.imgur.com/LR5d7Dg.jpg)
![Image](https://i.imgur.com/ULO4DzM.jpg)
![Image](https://i.imgur.com/k4m8xc7.jpg)
![Image](https://i.imgur.com/LeIaHdV.jpg)
![Image](https://i.imgur.com/K12WkcF.jpg)
![Image](https://i.imgur.com/ABKITju.jpg)
![Image](https://i.imgur.com/m1oCbSK.jpg)
![Image](https://i.imgur.com/fgTv4HX.jpg)
![Image](https://i.imgur.com/w3XaeIG.jpg)
![Image](https://i.imgur.com/yLhxmqw.jpg)
![Image](https://i.imgur.com/1rT8VO9.jpg)
it has ps/2 cable, but with the usual active ps/2->usb, it did not workMuirium wrote: 29 Sep 2021, 17:04 Spherical Topre niceness! And a cylindrical nav keys, F-row and numpad just for comparison's sake. Whatever your taste in thocc they have got you covered!
What's on the other end of the cable? Is it usable as a modern JIS keyboard?
It’s just average topre hi-pro pbt, looks like 45g domes, but the spacebar feels a bit stiff, because of using 2 additional springs.Jack/> wrote: 29 Sep 2021, 17:48 Did you like the quality of the plastic ( thickness ) . And in general, how does typing feel ?
Right. That’s why I asked. Suspected it would be something odd. Don’t know why, an old timer’s intuition.Damonskv wrote: 29 Sep 2021, 17:40 it has ps/2 cable, but with the usual active ps/2->usb, it did not work
