I had been using a cheap aula keyboard that sounded pretty meh. I was fine with it for a while until the "e" key started acting up. so here we go.
Looking for a keyboard that:
Sounds okay
75% layout
is 25-40 dollars in price
Could be a kit, keyboard with keycaps and things sold seperately, doesnt matter.
wired or wireless, probably wired at this price.
black, black and orange, black and white, or black and purple,
Mechanical
doesnt need to be hotswap but would be better if it was
I know this is a very tight budget but I want a keyboard that isnt a garbage membrane office one, but not too crazy expensive.
Thank you in advance.
25-40 dollar keyboard that sounds ok
- Main keyboard: IBM Model M(Lexmark Blue Badge, 1994)
- Main mouse: Logitech G502
- Favorite switch: Buckling Springs, Vintage MX Black, Alps Blue
closest I can suggest you is barebone Zuoya GMK81, which is 50$ barebone 75% kit.
edit: found even cheaper one at whopping $37, named ESC75. it's on aliexpress.
