Tt eSports KNUCKER mechanical(?) keyboard
ShuttleMunky
09 Nov 2012, 19:29
I bumped into this keyboard.
http://www.youtube.com/watch?v=62i7HvCy2yY
its an inexpensive gaming keyboard with mechanical like keyswitches. I dont know what they are so please someone explain. they sound really nice and the keyboard looks solid and looks like an alternative to people to make transition to mechanical keyboards
RC-1140
09 Nov 2012, 19:55
The switches look like ordinary slider over rubber dome or slider over membrane mechanics, so just fancy rubberdomes with exchangable keycaps. As they say that it's a combination of mechanical and rubber dome keyboard it probably is either a fancy rubber dome, or something like the Cherry MY. Either way, not very desirable imho.
It might as well be some new mechanical switch, but I really doubt it.
bounce
09 Nov 2012, 20:02
hm it uses the bigass enter key just as my SS7G, i think the only "mechanical" thing about this is the white plastic slider which pressures the rubberdome instead of the keycap itself doing it on other rubberdomes.
ShuttleMunky
09 Nov 2012, 23:56
So when this is done by Topre switches they are awesome and worth 300$ , and some other brand does this and it is worthless and "just another crap" ? :=)
Kidding. Isnt this similar to it seriously? Because it sounds identical at least.
Topre Enthusiast
10 Nov 2012, 00:07
They're common in that they are both "dome with slider" boards but that's about where the similarities end.
http://deskthority.net/wiki/Rubber_dome
Topre is capacitive and the Knucker is very likely membrane. I've never used the Knucker before but I can almost guarantee it's not of the same build quality as a Topre board. Most people here could tell you the myriad other reasons why Topre is better but to answer your question bluntly:
ShuttleMunky wrote:Isnt this similar to it seriously?
No.
ShuttleMunky
10 Nov 2012, 00:28
Okay i think i need to try a topre to find out. :) You are most likely right.
bounce
10 Nov 2012, 00:43
i just now noticed i should have made my post above a little more questionable.
all i wrote is pure speculation and afaik ive never typed on a tope board before so i cant make out the similarities or differences.
Icarium
11 Nov 2012, 11:58
There are a lot of factors that contribute to the feeling of a key. Considering that many people bottom out anyway a rubber dome is not technically worse than a Topre. (The main benefit of the capacitive technology in Topres is that you don't have to completely press the key for it to register but most people do so anyway. Topres are just generally very well built.) This is consistent with people liking some high quality rubber domes. What was that Dell again?
laffindude
11 Nov 2012, 15:36
It's an iRocks.
rodtang
11 Nov 2012, 15:59
Icarium wrote:What was that Dell again?
Dell QuietKey.
