KeyReMap4MacBook is now Karabiner. This excellent and free keyboard remapping software has long suffered from an unwieldy name. Finally, the name has been changed to something much more manageable. I highly recommend this software for anyone who uses a Mac and who would like to customize their keyboard layout without installing a Teensy or other circuit board. The software is quite powerful and easy to use.
https://pqrs.org/osx/karabiner/
There is a companion program called "Seil" available at the same site for the Caps Lock key and some international keys in PC keyboards.
- Hypersphere
- Main mouse: Logitech G403
- DT Pro Member: 0038
Phew, that name alone was enough to put me off ever installing it. (You can tell a snob like me could never handle Linux…)
Now it's just the /System/Extensions side of it that puts me off. Much like VirtualBox.
But for anyone using unprogrammable USB keyboards (including their Mac's built in one) this software is a godsend.
- Hypersphere
I can enthusiastically recommend this software. Note that it can be used alone or in conjunction with other remapping solutions. I have not encountered any problems with it, and it works beautifully.Muirium wrote: Phew, that name alone was enough to put me off ever installing it. (You can tell a snob like me could never handle Linux…)
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
I recommend it as well. It's great for using with external keyboards that I have not figured out how to program (yet).
The name change really threw me off, though. I had no clue what the computer was asking me to install. Personally, I prefer the blunt and unwieldy name.
- Hypersphere
The name change took me by surprise as well -- that is what prompted me to post about the name change. I also wanted to share my positive experience with the program, regardless of what it is called.
