Futaba linear lock
Jump to navigation
Jump to search
This article requires additional photographic illustration |
Manufacturer | Futaba |
Family | Futaba linear switch |
Switch type | Latching lock |
Sense method | Metal leaf |
Switch mount | Plate mount |
Futaba linear lock is a provisional name for a latching action switch in Futaba's range of linear switches. The switch is a variant of the Futaba complicated linear and appears to share the same moulds.[1]
Contents
Description
In all examples discovered so far, the switch shell is black, with a very dark grey slider.
The extra recess above the slider, which is redundant in the complicated linear, holds a slot-in block that bears the latch track. The single-piece slider holds a follower arm that runs inside this latch track. It's not clear whether the slider contains a rubber damper; if not, the switch overall will have one fewer part than the complicated linear, for a total of 15 parts.
Keyboards
- Commodore 8032-SK (in a keyboard module manufactured by Mitsumi)
- TeleVideo Model 925 CRT Terminal keyboard (Alpha Lock key)[2]
- TeleVideo TS-800A satellite station keyboard (Alpha Lock key)[1]
- TeleVideo TS-802 workstation keyboard (Alpha Lock key)[1]
- TeleVideo TS-825 keyboard (unknown product) (Alpha Lock key)[1]
Gallery
References
- ↑ 1.0 1.1 1.2 1.3 Geekhack — Televideo Terminal Keyboard Posted 2013-10-09. Retrieved 2015-07-26.
- ↑ Deskthority – Bunch from a storage unit
