Leading Edge DC-3014
Jump to navigation
Jump to search
FCC ID | None[1] |
Branding | Leading Edge |
Keyswitches |
Alps SKCM Blue Alps SKCL Brown |
The Leading Edge DC-3014 is a fairly uncommon Alps switch keyboard with a near-standard ANSI layout.
The 3014 uses the AT protocol with a 5-pin DIN connector.[1] A follow up test using the "blue box" converter, performed by Ohaimark, confirmed its use of the AT protocol.
Switches
In most cases, these keyboards are found with Alps SKCM Blue switches.[1][2] At least one has also been found with linear Alps SKCL Brown switches.[3]
References
- ↑ 1.0 1.1 1.2 EVA RIDER — Leading Edge DC-3014 Alps Blue SW
- ↑ KBDMania — 알프스 블루 형제들
- ↑ KBDMania – NEC 일본산과 태국산 차이??
