Sejin Futaba-mount dome
Jump to navigation
Jump to search
This article requires photographic illustration |
Manufacturer | Sejin Electron |
Switch type | Tactile |
Sense method | Pressure membrane |
Keycap mount | Futaba inverse cross |
Sejin Futaba-mount dome is a rubber dome switch from Sejin Electron with sliders with the same mount as standard (not Cherry MX mount) Futaba clicky switches. This may have been created to reduce costs without the need to retool the keycaps.
Sejin Futaba-mount dome keyboards can be clearly differentiated from Futaba clicky switch keyboards, as the former have only a sheet plastic moulding to support the sliders. The design looks similar to Noppoo capacitive switches, but with a more Mitsumi-shape slider shaft surrounds, and inverse cross instead of Cherry MX mount sliders.
Keyboards
References
- ↑ ちゃたりたいね — SEJIN SKR-2233J スライダー+ゴム枕 (Japanese) Dated 2012-12-22. Retrieved 2015-08-01.
- ↑ Kaineko2 — Unity KEYBOARD (Japanese) Retrieved 2015-08-01.
