So, my SSK has developed a problem...I cleaned and bolt modded the board about a year ago. Smooth sailing since then, until now. When I press e, d, or c lowercase all is well. If I use ctrl + c I still get a copy command. But if I use shift + e, d, or c I don't get anything. Actually, it depends on if I use left or right shift.
| E | D | C |
| L Shift | no | no | no |
| R Shift | yes | yes | no |
Another clue: caps lock + e, d, or c does work, of course, I think this is more OS than the keyboard controller.
So the keys definitely work, it's just when I modify them with shift that I get nothing. Any thoughts?
