Nixies ?
- DT Pro Member: 0167
as far as i know they are just vintage blacks with a clear top
that being said i would try em out if it was on its way around europe
- Stabilized
Yeah me too, I would like to see what all the fuss is about.
i am going to finally get around to harvesting the 2 wise boards i have, if i have any left over i can do the same with vintage blacks. I think only the wise 50 i have is a true vintage black with the lighter spring and all
i am retrofitting them into my filco tkl so hopefully i will have some left
- ramnes
- ПБТ НАВСЕГДА
- Main keyboard: KMAC LE
- Main mouse: Zowie AM
Nice. That would be great if the first destination is andrewjoy so he adds vintage blacks (and normal blacks if possible) on the PCB so we can really compare things.
Demystification incoming!
- HzFaq
- Main keyboard: Phantom
- Main mouse: CST L-Trac
- Favorite switch: MX Clears
It's going to be a while before I get around to it, I've got quite a bit on my plate at the minute.
My plan would be to hacksaw up a numpad into clusters like ceesa's little WASD switch try boards and have one with Nixies, one with "modern" blacks and one with reds or something. I can do an extra one if andrew is up for supplying any spare vintage blacks so there will be even more comparison.
My only worry would be that as Nixies aren't particularly common that it would go missing...I supose that is a problem with all of these switch try boards though.
