With a programmable keyboard I can finally replace all the useless keys with something better, like META, SUPER and HYPER. Then I could use these new modifier keys in Emacs. However, I haven't found any way of creating these modifiers in Windows (it's easy in Linux), but I can remap then to something else like F13 etc. Finally, I can't figure out how to map F13 to HYPER in Emacs! It's easy to map the 'Windows key' to HYPER, but the only way I've found is to map F13 like a regular key, but this doesn't allow for complex keychords or holding it down for more than a few seconds.
Any Emacs gurus here who know how to do this?
Create META SUPER HYPER in Windows
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
IANAEG, but this seems to list the method and also the inherent problems of low level Windows bindings:
http://xahlee.org/emacs/emacs_hyper_super_keys.html
- Minskleip
- Main keyboard: HHKB Pro 2
- Main mouse: CM Sentinel Storm
That's the best information I've found on the subject, but it only let Emacs map the windows and app keys, not arbitrary keys. I want windows, app, meta, super and hyper
Edit: maybe it could be possible to make some kind of Autohotkey concoction, where for instance F13 is sent as RWIN if the active window is Emacs..
- Minskleip
I think I'll end up doing something like this (in a check if active window is emacs clause):
When pressing F22 and F23, Ahk waits for the next input, and it that is `h', sends to Emacs, which interprets it as a regular key chord. This way I can make custom mega long bindings which doesn't interfere with Emacs' defaults, and trim them with Ahk.
Still not as cool as having the real deal though...
Reason for dong this: I want to use Emacs for Lisp programming, but I don't want to learn Emacs
F22 & F23::
Input, OutputVar, L1
if OutputVar = h
SendInput !{F22}^hs
return
returnCode: Select all
M-<f22> C-h sStill not as cool as having the real deal though...
- Minskleip
Found a third option here[1], and using the windows keys for super and hyper started working
By programming three keys on be F21, F22 and F23, it's possible create hotkeys with Autohotkey which sends input/macros to Emacs causing it to set either super, hyper or alt (or meta, so you can mix and match if you want to use app for meta or not) "Emacs modifier bits"! Unfortunately you can only set one bit this way, but because app can be set to meta, one can use such key chords as "C-M-A-H-S-key"[2][3] lol
Autohotkey:
F21::
SendInput ^x@m
return
F22::
SendInput ^x@s
return
F23::
SendInput ^x@h
return
#IfWinActive
It would probably be better to use the windows keys in practice though, because they being real modifiers can be hold down for issuing multiple hyper-bindings without emacs going off.
This is how you can stop win+r from starting the run dialogue while in emacs:
#IfWinActive ahk_class Emacs
LWin & r::
Send {LWin Down}{F13}{LWin Up}
return
#IfWinActive
Then bind H-<f13> (assuming left windows is hyper) to some command.
[1]: http://www.gnu.org/software/emacs/manua ... -Keys.html
[2]: I tried with C-M-x where M was made by a f21 programmed key.
[3]: With this method you can just press and release the special key; holding it down makes the hotkey repeat itself (since the keyboard key is really just a key and not a modifier). Maybe I should program a key to turn off auto repeat
Edit:
Emacs can use scroll lock as a (locking) modifier. It works great, and one can use Autohotkey to simulate two key presses if you don't want it to lock:
ScrollLock::
Send {Blind}{ScrollLock}
return
ScrollLock Up::
return
With this it's possible to have hyper, super and windows! Getting close to 98% success. 99% would be to recompile Emacs to use arbitrary keys as modifiers, and 100% would be to actually have hyper and super etc without hacks!
Autohotkey:
F21::
SendInput ^x@m
return
F22::
SendInput ^x@s
return
F23::
SendInput ^x@h
return
#IfWinActive
LWin & r::
return
#IfWinActive
Edit:
ScrollLock::
return
ScrollLock Up::
return
- Minskleip
There's no scan codes, so you'd have to write your own driver and rewrite all software to be able to use the new keys
The real solution to my problem, however, is to recompile Emacs so that w32-lwindow-modifier et. al. refer to other keys than LGUI et. al. This really should be configurable in Emacs already, at least on Windows where we don't have xmodmap to create hyper and super.
- Minskleip
A better Autohotkey hack for making scroll lock not togglable which doesn't make it go retard and mess up Teensy:
ScrollLock::
SetScrollLockState, On
return
ScrollLock Up::
SetScrollLockState, Off
return
ScrollLock::
return
ScrollLock Up::
return
