Since I don't have a github repo, I've migrated my release page to the DT wiki for the Easy firmware.
http://deskthority.net/wiki/Easy_AVR_US ... d_Firmware
Looks like Google has already noticed.
Rehosting some content
- metalliqaz
- Main keyboard: Leopold FC200R
- Main mouse: Logitech G400
- Favorite switch: MX Brown
- jorgenslee
- Main keyboard: Viper/HHKB
- Favorite switch: Ergo Clear
I have to register to thank you for this metalliqaz. I found a google cache of your page on geekhack but unfortunately it was dated around March and can't find the latest one. I use your firmware to program my JD40 and it works perfectly on windows but not on Mac. My JD40 on mac is not registering keys other than the alphas, I hope this latest version could fixed it.
- metalliqaz
- metalliqaz
Hmmm, I'd be very interested to hear your feedback on this. I don't own a Mac or know anyone who does and therefore can't test it. I doubt that the new version will improve for you. I suspect the problem is with the NKRO, which changes the way the USB HID device reports to the host PC.jorgenslee wrote: I have to register to thank you for this metalliqaz. I found a google cache of your page on geekhack but unfortunately it was dated around March and can't find the latest one. I use your firmware to program my JD40 and it works perfectly on windows but not on Mac. My JD40 on mac is not registering keys other than the alphas, I hope this latest version could fixed it.
Try using the config console to turn off NKRO. I'll bet that will make it work.
- romevi
- Main keyboard: Realforce 87UB
- Main mouse: Logitech G502 Proteus
- Favorite switch: Can't decide!
Ooh, I'll look for that once it's back up.metalliqaz wrote:NoHowever there is a similar project by SamwiseKoi (IIRC) on Geekhack called the GH36. That might suit your needs.
I actually have a few leftover PCBs that I never built, I should try and find those...
And if you have any more PCBs...
- jorgenslee
Reporting back that turning off NKRO fixed my issue. Is there a setting to make the 6KRO the default setting?metalliqaz wrote:Hmmm, I'd be very interested to hear your feedback on this. I don't own a Mac or know anyone who does and therefore can't test it. I doubt that the new version will improve for you. I suspect the problem is with the NKRO, which changes the way the USB HID device reports to the host PC.jorgenslee wrote: I have to register to thank you for this metalliqaz. I found a google cache of your page on geekhack but unfortunately it was dated around March and can't find the latest one. I use your firmware to program my JD40 and it works perfectly on windows but not on Mac. My JD40 on mac is not registering keys other than the alphas, I hope this latest version could fixed it.
- metalliqaz
It is permanent until you change it again in the config console
