Spacebar actuation
Lynix
- Main keyboard: CMStorm trash
- Main mouse: G502
I'm a noob to keyboards, but I'm going to make my own just cause. Should the spacebar have a larger actuation force? (Looking at building with the Phantom PCB, on a side note: Where can I find a mounting plate for it?)
jacobolus
- Favorite switch: Alps plate spring; clicky SMK
I hate stiff spacebars.
The main reason spacebars are stiffer is that they used to be extremely long, sometimes as long as 10 or 11 letter keys. In order to return such a long keycap it was necessary to make the switch under the spacebar extra stiff, or sometimes to add an additional spring to help return the key.
In my opinion spacebars should be split in half and no longer than about 3 keys for each part, or ideally less. But even for a spacebar which is 6 or 7 keys long, most standard switches are strong enough. I personally advise just using the same type of switch as the rest of the keys, or maybe a just slightly stiffer switch.
Of course, it all comes down to personal preference. Put whatever switch you like under the spacebar, and give your thumb a good workout if you prefer.
- Chyros
No. At least, not for me.
Spacebars, especially old spacebars, tend to be quite heavy and weigh a lot more than normal keys. I wouldn't mind if the switch under it is calibrated to take this difference in weight into account - but with the result requiring no more net force than a normal key.
I'm using a keyboard with a particularly stiff spacebar at work now and it's taking some getting used to xD .
- derzemel
- Main keyboard: FC660C, SSK, TX-1800 Nixie
- Favorite switch: Alps SKCL/SKCM tactile
I think that for light linear switches (MX reds, Gateon Clears, etc) a stiffer spacebar is necessary (eventually flipped for comfort). This is because I tend to press the spacebar with the side of my thumbs, so I do not have all the finesse of the other fingers.
Now, if I use tactile switches like MX Browns or MX Blues, probably MX Clears (but I haven't tried them yet) a stiffer specabar is a bit uncomfortable in long writing sessions.
Anyway, it boils down to typing preferences and habits. If you are a heavy typist, then a stiffer spacebar would be ok. If you type without bottoming out, then the change to a heavy spacebar will seem strange, maybe uncomfortable with the risk of not getting used to it.
A good idea would be to find a plate that allows you to remove switch tops. This way you can use any spring you would like, even change stems.
Yeah, it's entirely a matter of taste. I've typed on a 100% MX red keyboard before (standard 6.25 unit wide spacebar included) and found it perfectly fine. But I've no plans to take out the spacebar springs from my Topres.
MX isn't particularly smart about handling this. For a heavier spacebar, you do indeed need to put the extra weight (a stronger spring) inside the spacebar's switch. Most MX keyboards are plate mounted and make this a tricky proposition. It's childsplay on Topre though, where the spring sits loosely around the outside of the switch, and can be removed just by picking it up.
I'd try some keyboards if I were you. You'll find that you have a preference, even if you don't know what it is yet!
- DanielT
- Un petit village gaulois d'Armorique…
- Main keyboard: Various custom 60%'s/HHKB
- Main mouse: MS Optical Mouse 200
- Favorite switch: Topre/Linear MX
I like my spacebars a little on the stiff side. I use very light springs in linear MX Blacks (55g) so on the spacebar I always have a 68g spring. I'm a creature of habits so I have the same thing on all my keyboards (MX ones)
- SL89
- Main keyboard: CODE 104
- Main mouse: Logitech M570
- Favorite switch: Cherry MX Green
- DT Pro Member: 0095
iandoug
- Main keyboard: MS Natural (original)
- Main mouse: Kensington Expert Mouse trackball
Doesn't it depend on if you are planning on using the space bar as a fire button in games? Or some other non-space application.
