1000px: http://imgur.com/a/xkPKu
Full res (up to 36MP): http://imgur.com/a/JOf12
Haha yeah, good point xD . That would definitely explain some xD .
I've got some food for thought. If I like my board I might well be tempted to use the PS/2 cable that HzFaq is sending up to make a pinout with my multimeter and then use the cut cable to create a built in PS/2 to USB converter with a full size USB B port on the back of the keyboard, just so I can use it on everything. For now the keyboard is destined for my i7 though, which has a PS/2 port, so I'm all for using the PS/2 cable as a perma-solution. I guess it would be cool having a panel mount USB B port on the back of the keyboard though if anybody wanted to try that, the idea is there. If you want to try it I'll be more than happy to send you the results of the pinout should they not exist elsewhere.
A cheap, quick and aasy retrobrighting method presented here:
