Now that I'm doing mech eng at university I have access to some high end 3-axis CNC mills for free prototypes, so I decided I would start the design process for two customs : A TKL and a 65%.
Before I could start designing I needed to find PCBs to use. I'm fairly sure that I will be using Leeku's TKL and 65% PCBs but they're currently undergoing revisions, so for the time being I've decided to design the first prototype of the TKL for use with the B87 PCB.
I've spent the past few days coming up with a design. Here's what I have so far : The TEK-α (name not final). Not finished yet.. Still need to add a weight to the base and some details such as screw holes, etc. May change the design of the base piece.
The idea behind that odd shaped thing on the base piece in the last picture is that it will have a rubber/foam adhered to it, and it will apply force to the rim of the plate when assembled, dampening the plate. I'm not sure how feasible having rubber/foam on it is, so if it turns out that it will be very tricky it may end up being ditched. If anyone has any ideas for how I could attach foam/rubber to this ledge I'd love to hear it. I was thinking about having the strips laser cut from a rubber/foam sheet with adhesive backing.
65% will have a similar design and tentative name is TEK-Ω
