CM Bram wrote:
I loved reading your story! And since you mentioned Informatique I am assuming you are from NL? If so, our EU HQ is actually located in Eindhoven, NL and also we have a CM corner in the local paradigit just arround the corner where you can also have a moment to test the NovaTouch TKL!
Plans for a second tour, not yet, but if the interest is there, why not?
Thx for your reply..
Yes i live in NL In "Den Haag" Near the cost actually. That's 1,5 so 3hours drive from Eindhoven.
Also i find ParaDigit to be expensive. Thy want €180 for the NovaTouch thats $195 !!
Nuts if you ask me, that's as much as a new RealForce 87U.
Not all stores are this crazy mind you ..Others sell it for €125 thats $136 a bit better..
I know i know there is something like recommended retail price , and so forth doesn't really matter
Let's continue..
So yesterday i bought the Leopold FC660C topre keyboard because i love the Size.. And i own the FC660M with mx-clears.
There are a couple things on my mind i wish to share with you and of course anyone reading this post
As mentioned i had a brief moment typing on the NovaTouch and that wasn't a real good experience mainly because of the setting and the short time..
But after reading this post and seeing earlier posts in regards to modding i Started to see the a different site of the NovaTouch..
According to a couple of people these rings really improve the feel and sound of the NovaTouch
http://deskthority.net/help-f53/silenci ... 10051.html
And there is a keycap set that is supposedly the best one to use with this keyboard..
"Signature Plastics SA profile Thick ABS"
https://youtu.be/v93601o3FKA
Adding sum dampening material this keyboard could possibly be the greatest invention since sliced bread hahaha
In summary To mod this keyboard the way i would do..Would cost you an additional;
$50 best Keycaps for this board
$65 Topre rings
$30 Silens material like VibraFlex mats to cut and stick to the inside of the case.
Total $145 on top of the Store Price..So if the NovaTouch were around $110 it would be ideal for a pimp up mod project like this.. Competing and surpassing the likes of RealForce And Leopold ..
Because one awesome thing about the NovaTouch is that you can use Stock Cherry mx caps..
I would even go so far an try to trow in a teensy to make if fully programable using a OpenSource solution provided by the guys from InputClub.. So no need for expensive R&D hahaha..
Well that's my view of this keyboard with great Potential.. Of course it would take a great deal of time and effort..
But it would be like modding your Case..
