Another Prototopre switch used by Epson. As I mentioned in this post the other day, I currently suspect that these domes were designed/OEM'd by Brother for a variety of different companies. Unfortunately, there are very few markings on the pcb, outside what seems to be the PCB fab identification (GCMK-136EX). This particular board has the number KB-33B-3 which is similar to the numbers Brother likes to use (not all the Prototopre boards have these).
The reason for my naming them as Prototopre is that they are very similar to Topre's keyboard design but were introduced before Topre started making office equipment by at least a couple years (perhaps more). The later evolution of the domes (mylar membrane contacts) have extremely similar styles of domes (no springs though).
The foam is in pretty bad shape on these domes so most of the foil has fallen off. Also, I hate foam. Looking at you IBM and every other keyboard manufacturer that put foam in their keyboards. It sucks to clean up.
DSC03481
DSC03478
DSC03474
DSC03473
DSC03443
DSC03435
DSC03415
DSC03402
DSC03408
DSC03399
DSC03401
DSC03397
DSC03382
DSC03357
DSC03366
DSC03352
DSC03332
DSC03301
DSC03297
DSC03294
Flickr Album
Epson Q603A
- HaaTa
- Master Kiibohd Hunter
- Main mouse: CST L-TracX
- DT Pro Member: 0006
- Redmaus
- Gotta start somewhere
Are these switches actually nice to type on?
I also really really like the way you take your pictures Haata, they just have an amazing aesthetic feel to them.
- Chyros
Ah, more Brother dome and foil! Very nice pictures, Redmaus is right, you really have a way with your camera .
Interesting system on the flip-out feet btw. Not sure I've seen that before.
Also, capacitive PCB's are always nice to look at .
- HaaTa
Sorta, they fit on, and the keys press fine. But because they only have one slot, the keycaps angle forward.Mattr567 wrote: ↑Are those doubleshots Topre compatible? I know some brother keycaps are.
Funny story, when I met Edgar Matias for the first time (Toronto meetup in 2013), I brought one of these Prototopre keyboards with me. He said he preferred them to TopreRedmaus wrote: ↑Are these switches actually nice to type on?
Unfortunately, sometimes you get ones that feel super nice, others ones...not so much.
Also, thanks about the photos. I try to take them as I view the keyboard using the glare/sheen to show off the surface texture better.
Epson/Seiko used this style of feet a bunch of times (though only on the prototopres). I still think I suck with my camera, but they are definitely *alot* better than beforeChyros wrote: ↑Ah, more Brother dome and foil! Very nice pictures, Redmaus is right, you really have a way with your camera .
- HaaTa
Also, that particular connector is *THE WORST*. It's a discontinued DIN variant. I managed to find some by sheer accident a while back. It has a sort of horse-shoe shape so you really can't use the other DIN connectors.
That's funny, I think the little tab on the connector that helps you pull it out is a really nice touch.HaaTa wrote: ↑Also, that particular connector is *THE WORST*. It's a discontinued DIN variant. I managed to find some by sheer accident a while back. It has a sort of horse-shoe shape so you really can't use the other DIN connectors.
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
Not quite. I have some similar boards here and they are not Topre compatible.cookie wrote: ↑Seems like the caps could fit on topre
Topre mounts are cylinders with two slits cut in them at 12 and 6 o'clock. These mounts are cylinders with one slit cut in it at 6 o'clock. They won't fit Topre sliders. I've tried.
