White lithium grease
- Minskleip
- Main keyboard: HHKB Pro 2
- Main mouse: CM Sentinel Storm
Got any suggestions for keyboard friendly white lithium grease which are available in Europe? Shipping a $4 item for $30 from Amazon.com is a bit silly, so hoping to find something more local.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
RPM? Aren't we talking about keyboards?Simone4 wrote:White Lithium grease is very good grease for low RPM bearing surfaces because it has a high resistance to water intrusion. However at high RPM's its very bad because the lithium (metal) will eat into both the balls and races of common bearings, drastically reducing the life expectancy of the bearings. On a bicycle you would use white lithium on your headset and seat post but not your hubs or bottom bracket.
No, obviously about skateboards:
http://www.silverfishlongboarding.com/f ... post960164
(posted there 03-27-2008)
edit: obviously Simone4 deleted his/her post
Isaiah
- Main keyboard: Logitech
- Main mouse: Microsoft
- Favorite switch: heuger
I've recently puchased some Schunk two jaw chucks that arrived with a white lithium grease. We currently use a red lithium grease on our old chucks. Does anybody know what the difference is and is one better than the other?
ripster
- Main mouse: Mickey
Lithium grease is so Mainstream.
Silicone grease is the new Hipster favorite:
http://geekhack.org/showthread.php?2265 ... ent-Thread
