What do you mean by "silencemod"?
- Grond
- Main keyboard: Keychron K2
What's exacly a "silencemod"? I found several references to it here and on GH, but I could not understand what it is, and neither did I find a topic or wiki explaining what it means.
- CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
- CeeSA
- Main mouse: MM711
maybe the o-rings remember you more to pns ring and it's a amazing fantasy....
alternative your girlfriend should do it naked. or you do it and your girlfriend give you a blowjob
have fun
have fun
- DT Pro Member: 0011
Yes, it takes a little while to put them on.
Instead of the O-rings, there are also "orthodontic rubber bands". These might be better for original Cherry corp. keys, while O-rings might be better for keys from Leopold/Filco/Kinesis etc.
They should be 3/16" size, "medium" or "light". Not all are the same, though. I got two brands: one was marked "medium" and the other was marked "light" and the "light" ones cushion the stroke even more than the "medium" I have. They are not expensive. I bought 200 "light" bands for $5 + s/h on eBay recently, € 5 in total.
- Grond
I used to use those dental rubber bands when I was a kid, that was bad! But in this case it sounds like a good idea. I think I can get them at the chemist and try! I got my cherry doubleshots yesterday, but they seem louder than the pbts I used before.
How much is 3/16" in metrical units? I guess the smallest will fit, though.
- CeeSA
- Main mouse: MM711
jokes beside.
the o-rings i tried are not as soft as Rutschstopp.
I think the difference in height is also a bit less than with o-rings.
- Grond
What about this?
http://www.ebay.it/itm/4-8mm-3-16-100-P ... 115wt_1189
or this?
http://www.ebay.it/itm/100-BS834-Nitril ... 500wt_1156
or this?
I don't believe in using latex. Latex is a natural product that deteriorates. In humid climate, it can rot. In dry climate, it can dry out and crumble. That said, there are synthetic materials that also deteriorate. I have heard of black O-rings deteriorating after only five years.
That nitrile O-ring is much too thick. 3.53 mm! You won't be able to actuate.
- Grond
Thanks for the advice! However I'm not finding the orthodontic rubber bands on ebay, I should check at the chemist's.
EDIT: I couldn't find them even there!
Findecanor, would you sell me some of yours, if you have spares?
Tarkoon
For those who are interested:
I will get a few thousand O-rings in the right size in about 2 weeks.
It should be possible, that I share some for a better price than these ebay auktions.
(of course not cheaper than these "Pellet Bait Bands" but than the O-Rings =)
Tarkoon
If they fit in a standard envelope (weight max 50g) shipping would cost 1,45€ from Germany to UK or Italy. (I am not sure how heavy these rings are)
In a bigger envelope (called Versandtasche in germany, max weight 500g) the shipping would be 3,45€.
Both without insurance, but an insurance would increase the shipping cost unnecessary.
- Grond
Are those orthodontic rings? I remember them to be very small, they should fit in a very small envelope. Anyway, just let me know when you get the rings! I'll be in anyway. Thanks!
Tarkoon
No, those are no orthodontic rings but "real" rubber o-rings with an inner diameter of 5mm and thickness of 2mm made of Nitrile rubber or Neoprene (this decision is still open). Nitrile rubber would be a litter harder than Neoprene.
EDIT:
I fould a weight calculator. 125 pcs should weight about 8g! =)
EDIT:
- Grond
Yes, but it's hard to tell what's better without trying it on the keycaps, isn't it? "Better" may also be just a matter of personal taste, in this case. Maybe the softer material fits better on lighter keycaps/switches, or viceversa. I don't know!
- sordna
- Main keyboard: Kinesis Advantage LF / Dvorak layout
- Main mouse: Logitech M500
FYI wasdkeyboards sells proper size o-rings for $14 and shipping to Europe is only like $1.50
http://www.wasdkeyboards.com/index.php/ ... ies-2.html
