cherry mx brown weird sound
MechanicalBud
- Main keyboard: zowie celeritas
- Main mouse: a4tech V7M
- Favorite switch: cherry mx browns
basically, on my mechanical keyboard which is the zowie celeritas and uses cherry mx browns, the up key from the day i bought it had a weird feel and sounds like none of the other keys...i dont know if i should return it, or atleast before that im asking for advice here, if you want an audio/video file with the weird sound, i can post it.
MechanicalBud
nope, this is my FIRST EVER mechanical keyboard and i don't know anything about soldering or tearing it apart, because i only got it a month ago and i have a 9-year warranty.
- keycap
- Main keyboard: '88 Model M, DFK777 SKCM Blue
- Main mouse: A paperclip and a string
- Favorite switch: Alps SKCM, IBM buckling spring
You have a warranty? Contact the keyboard's manufacturer and try to get it replaced. We're talking about literally the up key, correct? Not a large key like Shift? And have you tried taking off the keycap to see if the switch has a moulding defect or is uniform with all the other switches?
MechanicalBud
It looks the same as the all of the other keys and actually i bought it from a local shop called ggwp and i might try to return it there so maybe they will ship it back to zowie i think.
also thanks for actually helping me out, because i went on geekhack and asked for this like a month ago and still no one has replied.
MechanicalBud
Please reply, because i want to return it after 2 days, and i want to know if it's worth returning it.
MechanicalBud
and now i find out that the F key does the same weird sound...
MechanicalBud
its harder to hear than in real life and it has a metallic sound
https://vid.me/3kSz
https://vid.me/3kSz
MechanicalBud
I just went to return it and the seller said that it's a normal sound please listen to it and give me info
- DT Pro Member: 0167
Sounds about right for an MX brown to me , will have another listen tonight at home with my better headphones
- cookie
- Main keyboard: HHKB Pro 2
- Main mouse: MX Master
- Favorite switch: Topre
Did you try different switches?
I'd return the board and go for a linear switch like reds or blacks. Brown and blues don't really add tactility, they just feel scratchy imho.
It could happen that switches feel different tough, this can be caused by stabilizers or key position or cap or a manufacturing error.
If you are as picky as I am, I'd recommend to return it and try another one or go straight for more even switch like I've mentioned earlier.
MechanicalBud
i've had it for 2 months now and the return policy is that i can only get my cash back within 15 days of purchase so i can't get a refund for it...cookie wrote: Did you try different switches?
here are the return policies where i bought the keyboard maybe i can replace it with another keyboard? http://ggwp.pro/return-policy
