Insert reply text to above quote here.7bit wrote: Insert text here.
[quote="7bit"]
Insert text here.
[/quote]
As you can see, it is the same for code-blocks.
Thanks!
[quote="7bit"]
Insert text here.
[/quote]
blockquote + br {
display: none;
}It should be better now (might need page refresh). If sixty doesn't start complaining that his chrome crashes, we're ok.7bit wrote:It's not important just looks a bit queer with all those large gaps.
Test Text.webwit wrote:It should be better now (might need page refresh). If sixty doesn't start complaining that his chrome crashes, we're ok.7bit wrote:It's not important just looks a bit queer with all those large gaps.
while(1);
Thanks!webwit wrote:Also fixed.
[quote="webwit"]Also fixed.[/quote]
Thanks!
xbb wrote:Should be fixed with Chrome 15.sixty wrote:As of today, this bug is back.
What version is stable now? 14?
webwit wrote:Unfortunately I had to revert it for now. Seems google is too busy selling ads or something.
