I'm looking for Cherry switches.
ArtoriasEdgeworth
- Main keyboard: Clueboard 66/Zilents/Originative
- Main mouse: Razer Naga 2014
- Favorite switch: Zealencioed Zilents, 45g
I'm looking for 67 Cherry Clears, a single MX Lock, and 15g springs to match.
- E3E
- Main keyboard: Blue, Neon Green, Striped Amber, Cream Alps, Topre
- Main mouse: Logitech, Topre
- Favorite switch: Alps, Topre
This makes me chuckle a bit too much. XD
Did anyone watch Zeal's video of using a Gateron Clear (35g actuation) spring with a Cherry MX Clear stem?
It stalled for like 10 seconds before popping back up.
15g would not come back up.
ArtoriasEdgeworth
Sorry, that was a typo! *35g. *facepalm* Thank you, ladies and gentlemen. I actually am looking for something so sensitive you can brush it and the keyswitch actuates.
ArtoriasEdgeworth
Browns' actuation bump is difficult to detect for me, and after doing a little bit of testing, I do think that a stiffer spring would leave me better off, so I think I'll stick with Clears, and spend a little bit extra for those 60 gram springs. Thanks for the recommendation, though! ^///^
ArtoriasEdgeworth
While I've got a captive audience (thank you so much for replying so quickly) which controller do you think would be better suited for my 68 key layout, a Pi 0, or a Teensy??
- Virtureal
- Main keyboard: Tipro KMX 128
- Main mouse: Kensington Orbit Trackball
You can still buy MX locking keys on Jack Humbert's site http://olkb.com/parts/lock-switch they are quite expensive, but they are also super rare and if they weren't 8 dollars a piece I would have bought a lot more than I did
ArtoriasEdgeworth
Danke schon, sir!!
