Please tell me if this layout can be improved! I wanted:
- symmetrical stagger
- fitting in a 60% case
- no stabs, meaning no keys bigger than 1.75 units
- no vertical keys -> freedom to play with different profiles
- navigation keys
- lots of thumb keys
- Shift (as the most used modifier) used by thumb, not pinky
- for the rest: no too far "away', resembling more or less a 'normal' keyboard
- Enter not too far to the right
The Enter key was hard. A 2.25 key would fit perfectly (but would require stabs). I've solved it with a 1.75 key plus some space. Advantage is that there is no mistake where the Enter is.
Of course all keys can be assigned different meanings. The key beween the B and N may be a good DELETE key.
Thoughts, critique? Thanks.
