IBM 3471 (dome unsaver)
- y11971alex
- Main keyboard: MacBook Air
- Main mouse: Microsoft Sculpt Comfort
- Favorite switch: buckling springs
- DT Pro Member: 0172
(forgive the potato pics)
http://imgur.com/a/KrHLq <- here is the full album.
The touch is quite firm, and I suspect even heavier than the Model M, but the tactility is quite noticeable and prominent. I can't test when it actuates, since I don't have the soarer's converter from orihalcon yet.
As for "Quite" Touch, it is indeed quite quiet, at least for contemporary standards.
- y11971alex
I don't think they're the same; these domes were made by Honeywell under the Micro Switch brand. They have square holes in a Model F-esque sandwich construction.hypkx wrote: ↑Are the domes the same as on a rubberdome model m?
How did the keycap/slider look?
Could it be possible to change the domes against model m flippers?
- y11971alex
Also, after some testing, this keyboard (internally at least) supports NKRO.
- y11971alex
I honestly have no idea. You might contact someone who has both an unsaver and this board, like lot_lizard, I think.chiptea wrote: ↑Is this case compatible with the cap bs unisaver?
