Keycaps for Novatouch?
the_marsbar
- Main keyboard: HHKB Pro 2 Type-S
- Main mouse: Apple Magic Trackpad 2
- Favorite switch: Topre
After reading that the Novatouch would be discontinued, I made a quick decision and bought one...
The thing is, I know nothing about Cherry MX keycaps. I own two other keyboard; a black HHKB Pro 2 with Hypersphere's silencing rings installed, and a Type-S. I really like the feel of the HHKB stock keycaps (I only have cheap rubber dome keyboards to compare to). I have a feeling I won't like the keycap set that comes with the Novatouch.
Any recommendations? I have read Muirium's review, and I really like the look of the DSA Dolch keyset, however, I realize that this will be difficult to find. I wouldn't mind blank keys. If the keys have legends, it would be nice with Mac-keys like cmd. I'm mostly interested in PBT caps.
Is the best bet to keep an eye on on Massdrop?
- Wodan
- ISO Advocate
- Main keyboard: Intense Rotation!!!
- Main mouse: Logitech G903
- Favorite switch: ALL OF THEM
Are you looking for danish keycap sets?
I'm afraid MechSupply just sold out the leftovers of their DSA Royal Navy ...
ANSI-US Keycap sets can be found from various sources, many even stock them. PimpMyKeyboard.com might have a few PBT keycap sets big enough for a TKL in stock!
the_marsbar
Sorry for not specifying. I'm mainly after ANSI-US keycap sets.
Thanks for the suggestions - I'll check them out.
- Wodan
- ISO Advocate
ANSI-US should be rather simple to find.
For the HHKB-lover:
https://www.originativeco.com/products/classic-black
For the HHKB-lover:
the_marsbar
I just finished installing Hypersphere's dampening rings in my NovaTouch. Actually I now like the sound even with the stock ABS keycaps. It's really good.
I still haven't managed to find a decent PBT keyset...
the_marsbar
I'm actually not that picky. However, I've read that the NovaTouch works best with OEM profile keycaps. I'd also like thick keycaps like the ones Ducky used to sell (I've read good things about those). I was looking for set Ducky set (like this: https://mechanicalkeyboards.com/shop/in ... ail&p=1322), but it looks like it's not available anywhere.
I don't like keycaps which are front-printed or engraved.
- Laser
- emacs -nw
- Main keyboard: Plum TKL \w Topre domes (work) / Novatouch (home)
- DT Pro Member: 0180
While laser-etched and not OEM height, these are not half bad (nice colors and legends, thick PBT Cherry profile) for their price: http://www.ebay.com/itm/Leopold-PBT-Key ... 2072639210
the_marsbar
Thanks for the link. Those are dye-sublimated - I would like that.
However, I've heard that Cherry profile keycaps might not be a good match for the NovaTouch. It's not specifically stated that the keyset is Cherry profile. Can anyone confirm?
- Laser
- emacs -nw
I have a set like this: http://www.ebay.com/itm/PBT-Keycap-Set- ... 1963267732 (but top printed, not front), which is also made by Leopold, and I believe they are the same profile (Ivan Ivanovich said in a GH thread that they are almost Cherry profile, enough not to be visible if you mix and match). I used the set on my Novatouch without problems.
- Scarpia
- Main keyboard: F77 / Alps SKCM Brown TKL
- Main mouse: Logitech MX Anywhere 2
- Favorite switch: Capacitive BS, Alps SKCM Brown
- DT Pro Member: 0223
I have that Dolch DSA set on my TKL. In fact, with the Dolch set, my RK RC930 Topre-clone looks exactly like Muiriums NovaTouch
But as you may know, that set isn't PBT. It's doubleshot ABS, so it may not be what you're looking for.
- zslane
- Main keyboard: RealForce RGB
- Main mouse: Basic Microsoft USB mouse
I have Dolch DSA on my NovaTouch too. It's a lovely combo, though I would like Dolch SA even better (if it existed).
I suspect, however, that the_marsbar doesn't like spherical keycaps and is really searching for cylindrical, mega-thick PBT with a soft, non-glossy texture. I don't think anything from SP would be acceptable to him, to be honest.
the_marsbar
I have to admit I've never tried typing high-quality ABS keycaps. I thought I'd go with what I know I like (Topre PBT) at first, then maybe I can try another profile/material later on. Does that sound all whacky?
- zslane
Sounds like we have a winner.
If you want something with a little color and would be willing to try dyesub PBT sphericals, I might suggest SA "Industrial".
the_marsbar
the_marsbar
Thanks. Expensive shipping to Europe is an issue (as well as VAT, import tax, etc.). I'll check those backlight-compatible caps out, and start looking out for some of the other caps mentioned on mechmarket. It seems like the market there is quite busy.
- 002
- Topre Enthusiast
- Main keyboard: Realforce & Libertouch
- Main mouse: Logitech G Pro Wireless
- DT Pro Member: 0002
Geekkeys have a very nice thick dye-sub set which I recently put on my NovaTouch. Shipping was cheap but it took quite a while to arrive -- worth the wait though. The only issue is there is no 1.25 'Fn' key, so you can see I just used the 'Menu' key. The other thing is, you need to trim off the additional stems on the spacebar because they block the stabilisers from seating properly. I actually used a large pair of nail-clippers (like these) to do this. Remove the pin that holds the lever on, so the clippers open up wide enough to get around the stem, then use a pair of pliers to clamp them shut -- perfect clean cut and it took less than 2 minutes
- scottc
Nice one OO2, looks pretty classy. That's a great price for the caps too. I'm using DSA granite on my Novatouch right now but Cherry profile PBT would be nice too.
- Laser
- emacs -nw
I think I recently saw a "for sale" thread that has a Vortex PBT set in this very forum. IMHO, the font is not the best, and, if thickness is a desired quality, I'd search for relevant pictures for any considered keyset before buying (because one thing I know, those Leopold keys I previously mentioned are thick)
OTOH, the Vortex keyset price is hard to beat ...
- Laser
- emacs -nw
- zslane
They look and feel identical to SA keysets in double-shot ABS, at least to me. I seriously can't feel any difference, apart from the lack of sculptured row profiles.
One interesting characteristic of the PBT keycaps is that SP put in a kind of "thickening" layer inside them, ostensibly to account for the lack of the extra plastic you get from a double-shot. This makes them pretty much equivalent to their traditional double-shot SA keycaps in terms of thickness and weight.
- infodroid
- Main keyboard: V60 Matias QC
- Favorite switch: Matias Quiet Click
I thought you might like to know about this site:
https://mykeyboard.eu/catalogue/category/keycaps_2/
They are selling pre-orders for ISO Vortex PBT doubleshots. No ANSI sets yet.
I don't know much about the site. But they are in based in Europe. They need to advertise more.
- Laser
- emacs -nw
Thanks! I'm kinda tempted ... although with shipping and VAT (I know SA prices are high anyway) ... so I still don't know if isn't better to wait for a customizable SA (ABS) set due to drop at massdrop, (long term, there's also 7bit's group buy and Matt3o's PBT sphericals project). But - thanks again for the info, it gives me something to put in the balance on this sidezslane wrote: They look and feel identical to SA keysets in double-shot ABS, at least to me. I seriously can't feel any difference, apart from the lack of sculptured row profiles.
- zslane
I neglected to mention that Industrial SA does not have any ISO support. There are only two kits available: an ANSI TKL kit and an ANSI numpad kit.
As for fully sculptured SA keysets coming out soon, SA Dasher/Dancer will hit MassDrop next month, though its ISO support is limited to an ISO UK kit.
- Laser
- emacs -nw
I'm just browsing through your Dasher/Dancer thread! Also, I intend to use the SA set on either an ANSI Novatouch, or (and after Topre->MX stems arrive) on a HHKB, so these are the layouts to cover - easy in the 1st case, not impossible in the 2ndzslane wrote:I neglected to mention that Industrial SA does not have any ISO support. There are only two kits available: an ANSI TKL kit and an ANSI numpad kit.
- NecromanX
- Main keyboard: B.mini
- Main mouse: Razer Naga Chroma
- Favorite switch: Zealios 67G
Hi. I am the owner of https://mykeyboard.eu.infodroid wrote: I thought you might like to know about this site:
What kind of advertisement would you suggest?
I will be adding ANSI keycaps this week. VORTEX PBT+POM ANSI sets in Black or in White.
- infodroid
Welcome to Deskthority! Making an announcement on the vendor board is probably a good start.NecromanX wrote: Hi. I am the owner of https://mykeyboard.eu.
