...And why a cheap rubber dome keyboard simply will not suffice!
(Also, I want this accent. Give me it.)
Why YOU need a well-built keyboard!
- Menuhin
- Main keyboard: HHKB PD-KB400BN lubed, has Hasu Bt Controller
- Main mouse: How to make scroll ring of Expert Mouse smoother?
- Favorite switch: Gateron ink lubed
There are good rubber-dome keyboards that perform more reliably and built better and give you better key press feels than many bad mechanical keyboards.
And I bet if you use the plastiky HHKB for such fights, it will fall into pieces.
- Thumper
- knock knock
- Main keyboard: Whitefox
- Main mouse: Razer Deathadder Chroma
- Favorite switch: Linear Zealios | Vintage Blacks
I heard my post box is a reliable proxy.Wodan wrote:If I look at them any longer, I will donate my TX-CP for their next round.
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
They appear brain damaged enough as it is,
not sure they need to be giving themselves minor concussions.
- Chyros
- Menuhin
Believe me, the IBM 8923 (rubber-dome successor of Model M) has a casing made of steel -- they won't be laughing at all after a single hit.
For ultimate brain damage results, of course these Soviet military keyboards are recommended:
P.s. have you tried the 2nd one by the way? Alps perhaps but not Hall effect I guess.
- vivalarevolución
- Chyros
- Mr.Nobody
- Main keyboard: IBM Model M/F
- Main mouse: Lenovo Big Red Dot
I wish somebody replaced those keyboards with Model Ms without telling these two dumbasses... if they need attention so badly, I think they need a cure as well...
