New Guy with Wire Question
Phroople
07 Jan 2017, 04:37
This might sound dumb, but it also might make good talk. But...ummm...what wire do people usually use to make a "PCB-less" keyboard? Like the gauge, the volts, the anything. Maybe some Amazon links would be good. Even just telling me your opinions on this type of thing would be nice.
,Thanks
07 Jan 2017, 07:47
It is 5V or 3V and relatively low-frequency signals and not much load, so I don't think the gauge matters that much. Just get some general purpose wire.
Many builders use ribbon cables where they can to make things a bit more organized. You could cut between the individual wires to divide them into single wires at the ends.
Phroople
08 Jan 2017, 02:53
I see, Thanks.
Cortes
21 Jan 2017, 00:48
In my last proyect use protoboard wire (int 0,6mm / ext 1,3mm):
Phroople
01 Feb 2017, 16:51
Thanks you very mooch, and awesome keyboard one of the more organized looking wired keyboards I've seen.
