Hello!
What is the proper thickness of a plate designed for MX switches and stabilizers?
In addition, what are the dimensions of each of the switch and stabilizer mounting holes?
Thanks.
Mounting Plate Queries
- Main keyboard: Clueboard 66/Zilents/Originative
- Main mouse: Razer Naga 2014
- Favorite switch: Zealencioed Zilents, 45g
- suka
- frobiac
- Main keyboard: custom split ergonomic "RedTilt"
- Main mouse: IBM trackpoint
- Favorite switch: MX red
- DT Pro Member: 0046
AFAIK 1.5mm thickness and 14x14mm² for a switch cutout is the spec, although for 3D-printed frames I use 13.85mm for a tighter fit.
Don't know anything about stabilizers as I don't use any
- suka
- frobiac
True, but as enlarging the squares with a sharp knife by scraping the edges is a very fast method of getting a good fit despite any building process tolerances I'd rather design them a little smaller than needed in the end - an old habit from my woodworking days I guess...
And even with the more accurate SLS the resulting smoothness is often beneficial, especially when your not aligning the cutouts in a plane like I did with my recent bowl-shaped model.
