I'm not sure if this information has come up before here, but I couldn't find it when I was looking for it (but admittedly didn't read every page related to TiPros), so ...
If you try to run the programming tool in a virtual machine and assign the USB device of the keyboard to the virtual machine, it fails – somehow it doesn’t like staying assigned to the virtual machine. However there is a fix for this – using the command-line VirtualBox tools to set up a permanent USB filter.
To assign, first of all determine the name of your virtual machine with :-
VboxManage list vmsNext, add a USB filter – you can normally assign it to “slot” (or index) 1, but you may have to check what slots are available if you already do this :-
VBoxManage usbfilter add 1 --target "W10" --name TiPro --vendorid 0x1222 --productid 0xfacaDuring programming it is helpful to remember than raw USB HID codes can be used by right-clicking in the input field for a key, selecting “Text Input” and inputing the code in the form “/${hex hid code} ${hex hid code}\” – such as “/69 69\” (a list can be found at: http://www.usb.org/developers/hidpage/Hut1_12v2.pdf)
Removal at the end:
VBoxManage usbfilter remove 1 --target "W10"(In case anyone notices, yes this was copied from my blog entry at https://really.zonky.org/?p=4470 but as nobody reads that it might be more usefully found here)
