Bluetooth compact mechanica KBs with removable batteries
vivalarevolución
formerly prdlm2009
22 Apr 2017, 19:59
So I am possibly in the market for a compact bluetooth mechanical keyboard with easily removable/replaceable batteries. I don't care much for the keyboard with the rechargeable internal batteries, because those always wear out sooner than I would like.
From what I know, the market for this type of keyboard is pretty slim. These seem to be the only bluetooth mechanical or electrostatic capacitive keyboards with removable batteries:
1. Filco Minila Air
2. Bluetooth HHKB
3. Bastron tablet keyboard that was on Massdrop
Is there anything else out there that I am missing? I am aware of other mechanical keyboards out there with USB wireless receivers, but I am not interested in those because I plan to use this keyboard with a tablet that will have limited connectivity.
vivalarevolución
formerly prdlm2009
26 Apr 2017, 17:19
Ahem
Madhias
BS TORPE
26 Apr 2017, 17:46
Wasn't there also a small Varmillo Bluetooth keyboard? But when I remember correctly I did not find it anymore, where to buy it.
Madhias
BS TORPE
26 Apr 2017, 17:53
This one: Varmilo VB660M
https://imgur.com/a/2RmSt
OK, it was about the batteries too...
chuckdee
26 Apr 2017, 18:50
I got a pretty good one... but no removable batteries.
https://smile.amazon.com/gp/product/B01N0QAB3V/
My JD45 was adapted for bluetooth and battery, but that's not standard, though you might try something like that. It was surprisingly easy to do (using the adafruit for the bluetooth); the biggest thing was the case.
vivalarevolución
formerly prdlm2009
27 Apr 2017, 18:19
Well thanks guys. I guess my choices remain as slim as I thought they were. Meh.
kergoth
17 May 2017, 22:24
I just picked up a Filco Majestouch Convertible 2 TKL https://mechanicalkeyboards.com/shop/in ... ail&p=2023, which is bluetooth, TKL, and uses regular replacable batteries.
