What makes this easier than the 60% mod is that I'm not taking off any chips, so the wiring shouldn't be as intense. What is being cut off are some resistors that link to the middle chip, which is for NKRO. Dork had to remove that chip (as it was in the way) and do a work around with the wiring. Not sure but I think he did end up losing NKRO as a result.
I have an idea for getting around this. I could use a breadboard to recreate the connections to the middle chip and by that way I could effectively USB-ify the Pingmaster as normal since everything is still there. Other and all ideas are welcome. Wiring is the biggest hurtle for this project.
I have plenty of wiring and soldering skills so I do feel up for the task but I'm not sure on where to cut, where to wire etc. After this can serve as a great guide for future people! I have a feeling i'm not the first to come up with this idea, but I am the first to actually try it as far as I know.
The physical cutting part shouldn't be too bad, as long as you know where to cut etc. I only have hand tools on hand (heh) but I know those won't do, a straight line is critical.
Here is the layout i'm aiming for. As you can see it is very reminiscent of the F77. Hence the name P77
Thanks for all the help! I hope for this project to become fruitful
