The housing has been made of stainless steel(top and bottom cover) and acrylic plastic.
- Old cherry, Filco layouts are supported ( not compatible with Filco housing and metal plate )
- 6 KRO in USB mode( PS/2 mode for NKRO is being developed but not supported in the first KMAC distribution )
- All function keys(F11 ~ F12) has hardware macro functionalities.
- ASDW LED can be on/off through any key which can be specified through KMAC tools( macro editor and firmware upload through USB port but not a ISP uploader).
- All the keys can be remapped by KMAC tools
And also there are a bunch of other functionalities.
The first GB is closed a month ago and the next GB will be opened next Febuary or later.
You can also find some more photos of aluminum alloy anodizing shell for KMAC GB here.
