Question for Cherry MX Blue owners
Okay, so I've bought a Cherry MX Tester and this is how it goes with Blues: If you press lightly, the first millimeter (1) of key travel is effortless but then you suddenly encounter a bump and need to apply a bit more force. So when you apply this force, you overcome a bump instantly and hear a click (2). Now, while pressed, if you reduce the force again, you return to the point where you originally encountered a tactile bump but the key is not actually reset yet (3) - it has to return to its full height by reducing force even more (4). But my tester doesn't have LED indicators so I'd like to know if you're at step number (3), is the key still activated (like holding down a mouse button) or does it register only once and then act as not pressed at all? I know it's a weird question, but I need to know how I can use my keys when gaming and if the key is actually still pressed-down at step (3), I can use that to circumvent hysteresis by reducing the force a bit instantly after a click so that I can press it again faster after while still holding the button for in-game action.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
I wonder there's no answer to the question yet,
perhaps there's just too much text around it
Basically, the question is:
Sorry, unable to answer myself.
- hoaryhag
- Main keyboard: IBM Model F PC AT
- Main mouse: IntelliMouse Explorer 3.0A
If you try to circumvent the click and press it again, the key will have already gone into repeating mode because you held it down too long. The faster you let off the key, the faster you can press it again.
- scottc
Seems like an spam account. None of the replies that this user wrote make any sense in their context. Just report it. Replying makes it harder to clean up.
