Spilled coffee on a Filco MJ2
cowabunga
02 Jan 2012, 13:32
Hi guys...
I spilled some coffee with sugar on my Filco Majestouch 2, it dried, and now some switches are a little bit sticky :( Is there a way to clean those without desoldering them?
Thanks in advance,
Don
mintberryminuscrunch
02 Jan 2012, 13:40
WD40?
sixty
Gasbag Guru
02 Jan 2012, 13:46
Realistically, if stuff made its way to the inside of the switch, you most likely will have to desolder and/or replace the switches. Some people had success bathing them in pure cleaning-alcohol, but I don't think it will be worth it.
Gilgam
02 Jan 2012, 20:48
pure water bath ?
gore
03 Jan 2012, 00:38
ripster
03 Jan 2012, 04:01
rane
04 Jan 2012, 22:25
I spilled coffee on my Filco just some time ago.
Opened it up completely, removed keycaps, and bathed the whole thing in distilled water. Someone also recommended spraying the stuff on switches while pressing them so it would get in them. Afterwards I let it dry for 2 days and it turned out to work perfectly.
ripster
04 Jan 2012, 23:57
Probably me.
I like stuff.
