I can't find a mechanical keyboard with cherry blue switches with multicolor and a row of macro keys. Please send links if you know some.
Thanks in advance
Yizwire.
Mechanical keyboard request
rich1051414
- Main keyboard: Whitefox Zealios 67g
- Main mouse: Logitech G900
- Favorite switch: Alps Orange
Multicolor is not the same as RGB. Multicolor means the keyboard has static colors per row, but difference colors per row, and you can't change the colors. I think they are simply tricking people into buying the wrong thing.
"row of macro keys" I assume you want a gaming keyboard? Is that what you are looking for?
https://www.amazon.com/RIPJAWS-KM780-RG ... l+RGB+blue
rich1051414
There is also this:
https://www.amazon.com/Logitech-Mechani ... ry+mx+blue
But I don't know if you can get it in RGB or not.
