EDIT since it seems people missed the original point of the question:
Which stabilisers are more tolerant of warped keycaps, Cherry or wire/Costar-style stabilisers?
After finding out that my Alps mount DSA Granite keycaps have MX mounts for the stabilisers while my Filco Zero's plate uses classic Alps style stabilisers (except on the spacebar), I now have a few options.
The cheapest would be to bend the existing wires (or buy some wire and bend it) and buy some MX stabiliser inserts for the keycaps. Alternatively I could buy a new custom plate with Cherry stabilisers, which would make it easier to remove stabilised keycaps.
But I started thinking about the slight warping on the larger keys and was wondering, which stabiliser type is more fussy about warped keycaps? I was thinking that wire stabilisers would be more flexible with warped keycaps, would I be correct in assuming that?
Which stabilisers are better for warped keycaps - Cherry or wire?
- DT Pro Member: 0011
I have a hunch that maybe stabiliser wires from a Monterey K208 might work with costar-style stabilisier inserts but I am not sure. I was trying to find my old one but I think that I must have thrown it away.
