Hello!
Quick question, for which I was unable to find an answer Googling around:
does the Novatouch pcb fits inside the Realforce case?
I already possess the former, plus a set of PBT keycaps, so I was wondering if it's possible to do since I like the Realforce case better.
Thanks.
[Question] Novatouch case swap with a Realforce
- zslane
- Main keyboard: RealForce RGB
- Main mouse: Basic Microsoft USB mouse
- Favorite switch: Topre
Unfortunately, no. The space separating the main block of keys from the nav cluster is different between the two. The space separating the F-row from the alpha block may also be a little different.
mannoso
Bummer, i like DSA profile keycaps and to me the look best on a flat case with large bezels.
Thanks for the help
- zslane
MX-stemmed keycaps with more than one stem (i.e., all the stabilized keys) aren't compatible with Topre switch housing. You'd have to drill holes into the Realforce plate to accommodate them.
