Also, while desoldering, I scratched two traces (and lifted a bit of a solderpad) on my PCB. Is using jumper wires OK?
Thanks in advance
What is a primer coat? I don't want a black color. Something very colorful instead.
The primer coats will cover up any dings or imperfections that appeared during sanding (and the small dents from your screwdriver). It also makes for a better surface for the main paint to "grip" on
I see. Thanks bro!Dingster wrote:The primer coats will cover up any dings or imperfections that appeared during sanding (and the small dents from your screwdriver). It also makes for a better surface for the main paint to "grip" onThe primer is usually grey but you will cover it up with your desired paint anyway.
Sangdrax wrote: Use a heavy enamel spray for durability. The stuff that's common and super cheap is the cans branded for recoating appliances. Very good coverage but color selection is pretty small. White, black, red etc.
I used the black for the steel bumper I welded for my jeep like five years ago and it still maintains a nice shine. And I used the same stuff on the Futaba plate I had to sand and restore recently.
I would not recommend a high build primer for this sort of thing unless the tolerances around the switches are pretty loose. Otherwise, you're going to run into fit issues.
For the PCB electronics, as long as the lifted pad has good continuity when resoldered to everywhere it's suppose to connect, don't worry. And for the scratched traces, just use good a non-conductive lacquer for repair. It's just lacquer coating the traces in the first place. Nail polish is particularly good for this. I've seen stuff like the adhesive from a piece of tape eat through the board lacquer after thirty or forty years and a quick brush isolates the traces again better than new.
I'm selling my green alps from the board though.
