Make your own IBM Metal badge - starts at 11:48
green-squid
- Main keyboard: --
- Main mouse: --
- Favorite switch: --
worth watching the whole thing BTW
- JP!
- DT Pro Member: 0194
I love these kind of videos.
- snuci
- Vintage computer guy
- DT Pro Member: 0131
I have a couple of IBM 5155 luggable XT computers. One of them had a foil label from the factory. It was quite strange. Not sure if I kept it because it was damaged but ig I did, I'll add a pic later. It looked similar to this "MacGyver label" but mine was silk screened
By the way, and good computer restorer would cringe at the stuff he is doing, in case anyone is wondering.
green-squid
- Main keyboard: --
- Main mouse: --
Yes, he sometimes fucks up (like the Osborne Retrobright), but what's wrong with the rest?snuci wrote: I have a couple of IBM 5155 luggable XT computers. One of them had a foil label from the factory. It was quite strange. Not sure if I kept it because it was damaged but ig I did, I'll add a pic later. It looked similar to this "MacGyver label" but mine was silk screened
- snuci
Most restorers would only use original parts and in some cases, period dated parts for internal ICs, for example. I understand he is trying to make things look presentable but even retrobright is not an option for most purists as it changes the composition of the plastic and makes the plastic more brittle.
green-squid
- Main keyboard: --
- Main mouse: --
Yeah that's true, but besides that, his restorations are pretty good and satisfying, aren't they?snuci wrote: Most restorers would only use original parts and in some cases, period dated parts for internal ICs, for example. I understand he is trying to make things look presentable but even retrobright is not an option for most purists as it changes the composition of the plastic and makes the plastic more brittle.
