![Image](https://i.imgur.com/PGuVowB.jpg)
Inside. This mouse was made in 1998, while my 1.3A was made in 1999.
![Image](https://i.imgur.com/9BUWIg2.jpg)
The switches I needed to replace
![Image](https://i.imgur.com/xk8va8b.jpg)
It was a very easy process.
![Image](https://i.imgur.com/NbYUchk.jpg)
New switches in
![Image](https://i.imgur.com/eUugkXX.jpg)
![Image](https://i.imgur.com/tlbJnqI.jpg)
So, are they any better? Yes they are better than the Omron ones, but they are still heavy to press, and I don't like that. But that's probably a fault with the design. Otherwise they would be great. but they wouldn't match my Dell Model M, like my Dell mouse. But that's just a nitpick.
![Image](https://i.imgur.com/LiYDTYq.jpg)
I like my current Dell mouse, but I wish the Scrollwheel was more silent, like the 1.1, and if it hade a bit better clicky switch, like my Logitech M-MD15L from 1989/90.
What do you think?
![Smile :)](./images/smilies/icon_e_smile.gif)
