Have no idea what's wrong with the wiki, but it literally forgets my new password every time I log out. I have to reset my password and log in with temporary, change it to a new password, and then I can log in. Obviously this is pretty annoying to have to change my password every single time I log in. Are there some kind of password restrictions that are automatically parsing my password and changing it?
For example, if I enter IUHTIR&B^r735(B(Wbjkdbja*( as a password, it will accept it and then no longer work once I log out.
Wiki passwords
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
- ScottPaladin
- Main keyboard: Can't pick a favorite
- Favorite switch: Fujistu Leaf Spring
I had some trouble with the wiki password system recently. After some troubleshooting, my working theory is that it chokes on large numbers of symbols and won't accept them. Try just upper/lower/numbers and see if that does it.
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
I recently got this bug report from someone with a similar problem of not working passwords:
I haven't looked into it yet. Does ^ break it?I think it's choking on either some combination of special characters or just the number of them (my QA instincts got tired before I narrowed it down). I've set it to a private password that works for both now, but here's some examples:
hFJSWA8uWxSurBjFVtdM8d <<Works!
hFJSWA8uWxSurBjFVtd^^^& << Doesn't Work
1Vtd^^^& << Doesn't Work
¯\_(ツ)_/¯
Maybe media wiki's not escaping stuff properly.
- Blaise170
- ALPS キーボード
Well I actually tried a 20 character alphanumeric with no special characters and it did not work that way either. I don't really feel like continuously trying passwords but unless there is a character limit (less than 12 for example) then there is no reason my 20 character alphanumeric shouldn't have worked.
- webwit
- Wild Duck
I've taken a look, it's not related to password length. It's probably related to the extensions' password hashing here, where it does evil things:
https://github.com/Digitalroot/MediaWik ... rdHash.php
I tried another plugin:
https://github.com/multidimension-al/phpbbauth
Which just uses the phpBB login session and doesn't require separate login, and it also fixes the problem of incompatible user names. However, it is not compatible with our outdated branch of phpBB.
- Blaise170
- ALPS キーボード
What would be the downsides of upgrading it? I'm not that familiar with the software so I expect there to be some changes but it would be great to only require one login in both places.
- webwit
- Wild Duck
We'd need to redo or get rid of some mods.
http://staging.deskthority.org/
Username: dtstaging
Password: InigoMontoya
Username: dtstaging
- Blaise170
- ALPS キーボード
Hm that's an interesting look. Well you are our benevolent dictator so I suppose that you have a good idea of what should be done in this situation. ![Razz :P](./images/smilies/icon_razz.gif)
- webwit
- Wild Duck
Yeah we should update some time, matt3o is running this, but the problem is it means work, and the technical committee ran off.
deskthority-f17/a-new-forum-software-fo ... 15780.html
- Blaise170
- ALPS キーボード
Hm I could help as much as I can. I'm not the best programmer in the world but I think I should be able to handle some of the smaller things... But perhaps this should go into that thread?
