What I don't like about the design is how big it is. It also has way too many buttons that I would never use. I simply need left click / right click.
I picked up a used unit on ebay for pretty cheap. My goal is to pop the guts out of the case and put them in a smaller custom enclosure. I don't really have a plan so we'll see where this goes but I started prototyping a smaller footprint with cardboard. I think this size is something that I could live with.
I had a lot of trouble desoldering the existing buttons and burnt a couple of pads off; hence the new wires soldered directly to the PCB traces. Depending on what the final design is, I'll adjust this hack to something a little cleaner (hopefully
Let me know if you guys have any cool ideas!
