SA Profile
Fully Sculpted
Gradient Colour Scheme
PKMN Inspired Novelties and Moveset kit
ISO-UK Included In Base, No Expensive Seperate Kit
Support for Ergo, Planck, Non-Standard and European Layouts
Due to the gradient it would have be an entirely new set of alphas and therefore very pricey.
So that we can really see the colors, would you mind putting a piece of white printer paper in the frame for white balance detection? If you’ve not done that, just put a bit in frame, on your phone click on the paper but keep the samples in frame, then shoot. Should make sure that it’s as accurate as possible. We can also run it through an editor after the fact if you’re using a camera and done know how to do this part.UKKeycaps wrote: 27 Mar 2019, 22:57 Here's a pic of the colour samples, these are from a while back but I didn't post them here.,
Being a custom colour set there is always some uncertainty from some GB participants whether the colours will come out as nice as the renders, however I think the colour samples shown good accuracy to the renders.
You do realize that this ended almost a year ago, right?eatanygoodbooks wrote: 16 Apr 2019, 02:36 This might be super obvious, but are these cherry switch or alps? If they were alps, my wallet would definitely be in danger.
Didn't notice that, but they are still available for sale on MechSupply in a variety of kits. Their product description links to here, so I figured to ask.Lbibass wrote: 16 Apr 2019, 03:14You do realize that this ended almost a year ago, right?eatanygoodbooks wrote: 16 Apr 2019, 02:36 This might be super obvious, but are these cherry switch or alps? If they were alps, my wallet would definitely be in danger.
And they are MX. Alps molds for SA don't exist. They would cost about 15-20k to do according to Clueboard
