[help] Xwhatsit for 5251 going haywire unexpectedly
raycewest
- Main keyboard: Ergo Infinity
- Main mouse: Corsair Sabre
- Favorite switch: SKCM Blue
Had one for my first 5251 that worked for months. Acquired another 5251 to restore, tested it with the same Xwhatsit controller with the same configuration (~131 voltage threshold, solenoid on) and everything worked perfectly. Put it back in the first keyboard and at some point (not sure if right away, or later) the sensing went way out of whack - a 130 threshold now registers a bunch of keys pressed down, dropping it to 120 detects nothing. I switched it to the new keyboard again, this time getting around the same whacky result. Can't find any unwanted solder bridges, swapped usb cables, and I don't think I did anything wrong. Anyone here have a similar issue? Thanks for any advice.
- PlacaFromHell
- Main keyboard: IBM 3101
- Favorite switch: Beamspring
Maybe you accidentaly burned it with static. Just to be sure, did you put the ground cable it? Sometimes we forget this things.
- PlacaFromHell
Sorry, I didn't understand correctly your first message. Don't worry, it's not burned. Verify your screws in the two keyboards, I had problems with a loose one who caused a similar issue. The controller seems to work but for some reason it's acting strange, and with the two keyboards. If at least works with the software something strange should be occurring between the keyboards and the controller.
